Resin pad replacement
My Shimano M416 discs are marked "Use Resin brake pads".
Is it OK to use - Shimano Deore 525 Semi-Metallic Compound
Item Number OBE-DS01SGx4?
by jrcrotty Tue Mar 29, 2011
Consider instead the soft Ceramic C compound OBE-DS01CG / OBE-DS01CGx4
http://www.discobrakes.com/?s=0&t=0&c=14&p=119&
For info on compounds see:
http://www.discobrakes.com/?s=0&t=8&q=compounds&
by support Wed Mar 30, 2011
Specifications subject to change. © Copyright DiscoBrakes.Com Pte Ltd 1999-2024
