Best bad weather brakes
I'm competing in Hel Van Kasterlee, 120km muddy MTB ride.
What are the best brakes, which ones don't fail for 120k ?
And they say u need to break the new breaks, heat them with braking when they are new.
How do I do this on flat roads ? Or can I heat them in a pan ?
Regards :-)
by Roflpain     Fri Oct 8, ...
For the ride you are describing you might be best advised to use Sintered pads. You can get further details on the various compounds here: https://www.discobrakes.com/?s=1&t=0&f=viewtopic.php?t=4384__a__amp;sid=fbe31d3f3df5eb5cf0d0701f7263d813&
With regards to the bedding in, please have a look at this article. It will give you some useful tips: https://www.bikeradar.com/advice/workshop/how-to-bed-in-new-disc-brake-pads/
We hope that helps.
Michael
DiscoBrakes Team
by Mikethebike     Fri Oct 8, ...
Thx, very helpfull.
One more small question where I struggle most times:
How to choose the correct brake pads?
I have sram groupset. But there are so many different options.
I think I have these ones: https://www.discobrakes.com/?s=0&t=0&c=2&p=838
These are correct not ?
Have a look at our Disc Pad Identifier: https://www.discobrakes.com/?s=1&t=0&f=viewtopic.php?t=4398__a__amp;
This should help you to find the right pads for your brake.
Michael
DiscoBrakes Team
