Les Angles 66 Degres Sud Gravel Debut - Jose rides with DiscoBrakes
Race overview
Les Angles sits high in the French Pyrenees, surrounded by forests, lakes, and ski slopes that turn into fast service roads in summer. It is a classic setting for mixed-surface riding with quick changes in grip and plenty of altitude. The UCI Gravel World Series brings a brand-new stop here under the 66 Degres Sud banner, so the venue blends fresh course design with an experienced local organizer.
Event day is scheduled for Saturday, 13 September 2025. The program offers two distances: a long course of roughly 110 km and a shorter option close to 74 km. Both routes roll straight out of the village on Avenue de Mont-Louis before heading into the surrounding high country.
Elevation is very much part of the experience. The start sits around 1,600 m above sea level and the route tops out close to 2,000 m, which means cooler air on the climbs and big, open views up top. Expect total elevation gain for the long course a touch over 2,100 m, delivered by a series of sustained efforts rather than one single wall.
Qualification rules follow the standard UCI Gravel format. The 110 km route serves as the qualifier for men 19–59 and women 19–49, while the shorter course covers men 60+ and women 50+. Age-group placement can earn a spot at the UCI Gravel World Championships, so pacing inside the right group matters as much as raw speed.
Course details and expectations
Terrain is a confident blend of compact forest roads, firm doubletrack, and short paved links where groups reshuffle. The lap winds through the Capcir and Cerdagne areas and threads past familiar landmarks like Formigueres, Lac de Matemale, and Lac Calvet. It is a route that rewards line choice and calm hands on the bars.
Climbing comes in clear steps. A first climb arrives around kilometer 10 to 15 to thin the field, a second effort builds again near kilometer 28 to 32, and a final two-part ascent bites between kilometer 72 and 87 before the run-in. Riders who keep cadence smooth on these ramps usually save enough for the closing kilometers.
Mountain weather can swing during a single race window. Mornings often start crisp in Les Angles, while the afternoon can bring dry warmth and a breeze across the plateaus. A pocket shell, light arm warmers, sunscreen, and clear-to-dark lenses cover most scenarios without overpacking.
Feeding and navigation are straightforward but worth a plan. Load the organizer's GPX to your head unit and follow course arrows at junctions. Carry enough fluid and carbs to bridge feed zones, then top up quickly without losing the group you want to ride with. A simple schedule like a sip every few minutes and a gel or small bite every 20–30 minutes keeps energy steady.
Bike setup notes
Braking confidence matters on high-altitude descents. Jose is on DiscoBrakes rotors and pads, which provide consistent bite and heat control when the course pitches down. Jose loves DiscoBrakes Ceramic compound for the best bite and Copper Free compound for being an all around great pad.
Tires make the day more than almost anything else. Tubeless rubber in the 38–45 mm range rolls fast on hardpack yet hangs on through loose-over-hard corners. Start pressures low enough to take the sting out of chatter but high enough to avoid rim strikes on rocky edges, and fine-tune after a short pre-ride.
Gearing should favor efficient climbing over outright top speed. A wide-range 1x or compact 2x with a genuine bailout gear keeps cadence smooth on the steeper ramps. Being able to spin instead of grind preserves legs for the final climb and the fast, flat-out sections that follow.
Spares and small tools are cheap insurance. Two ways to fix punctures (plugs and a tube), a mini-pump or CO2, a compact multi-tool, a chain quick link, and a small first-aid kit will solve most problems without weighing down the bike.
DiscoBrakes white floating rotor
Boom! Lumberjack shirt, a fortysomething's cap - covering the bald spot. I am here to tell you I have signed up for a gravel race. Yes, yes, yes. As I said I would, I have signed up for a gravel race. Heads up: I even paid the entry fee and everything! So tomorrow we will see in Les Angles what this gravel-racing craze is all about. And on top of that, it is a qualifier for the world championship, man. So off we go. That is right - we are making our gravel debut with a little 110-kilometer sightseeing ride through France and 2,100 meters of total elevation gain.
Strategy tips
A measured first hour is the best investment you can make. Let the early surges breathe a little, slide back into the wheels on the flats, and protect your legs for the two-part climb deep in the course. Strong finishes come from steady choices in the middle third.
Keep fueling honest with cues rather than feelings. Eat and drink on a schedule, even if the pace feels easy, because altitude and dry air can mask thirst. Small, frequent inputs keep the engine running and the stomach happy over rough surfaces.
Descend with intent, not aggression. Look through the corner, brake early while upright, release before the apex, and let the tires track cleanly on exit. Smooth lines preserve sidewalls and carry more speed than late braking in loose gravel.
Ride the pack like a teammate. Communicate, protect wheels, point out hazards, and rotate smoothly. Over 110 km, calm cooperation saves minutes for everyone and creates openings when it really counts.
Official info and GPX
Full event details and route files are hosted by the UCI Gravel World Series. Check the page for the latest course notes, elevation profiles, and GPX downloads: 66 Degres Sud - Pyrenees Catalanes Gravel Tour.
