Jose Antonio Hermida & DiscoBrakes: Semi-Metallic Power, World-Class Control
When you think of all-out speed, razor-sharp handling and a riding style that never stops having fun, you think of Jose Antonio Hermida. We’re proud to have Jose in the DiscoBrakes family, putting our components to the test on everything from World Cup-level terrain to his home trails.
In this new series of clips, Jose takes you through his brake setup with our Semi-Metallic pads, shows you how he swaps pads in the workshop, and then heads out for a playful “Moonwalk” session to prove just how much control a good brake setup can give you.
Why Jose rides DiscoBrakes Semi-Metallic pads
Jose’s riding is all about feeling the terrain and staying in control, even when it gets steep, loose, or just plain wild. That’s exactly where our Semi-Metallic pads come in – combining power, consistency and modulation for long descents, aggressive XC, or trail bikes that see a bit of everything.
Balanced bite and smooth modulation for confident braking
Consistent performance across a wide range of conditions
Great all-round durability for riders who are always out on the bike
Whether he’s sprinting out of a turn or dancing the bike down a rough rock garden, Jose knows his brakes will be there every single time he pulls the lever.
Step-by-step: Jose’s brake pad change
Good braking performance starts in the workshop. In this clip, Jose walks you through a straightforward pad change using our Semi-Metallic pads – the kind of simple maintenance that keeps your brakes feeling fresh and powerful.
Take a few minutes to follow along with Jose and you’ll be ready to hit the trail with a brake setup that feels precise, quiet and ready for anything.
Maximum fun, maximum control – the “Moonwalk”
Of course, riding isn’t just about race runs and split times. In this fun “Moonwalk” clip, Jose shows off the playful side of having powerful, predictable brakes – balancing, pivoting and floating the bike around with the kind of control you only get when your setup is completely dialed.
Moments like these are why we put so much effort into our braking components: more control doesn’t just mean more speed, it also means more confidence to play on the bike and push your own limits.
Ride like Jose – or at least brake like him
If you’re inspired by Jose’s riding and want that same blend of power and feel from your brakes, check out the Semi-Metallic range over at DiscoBrakes. With the right pads, a clean install, and a bit of Jose-style enthusiasm, your next ride could feel smoother, faster and a whole lot more fun.
