Why Rim Brakes Can Smell “Burnt” on Carbon Rims
A long, steep road descent can be one of the best parts of a ride - until something feels off. One concern riders sometimes notice with carbon rim brake setups is a warm, burnt-rubber or "burning" smell after extended braking. It can be surprising the first time it happens, especially with new pads.
The good news is that a smell doesn't automatically mean something is wrong. The important part is understanding what causes it, how to reduce it, and how to spot the warning signs that mean it's time to stop and inspect.
A light burnt-rubber smell on long descents is often just heat and pad material doing its job -- continuous braking builds temperature quickly at the pad/rim interface.
What's causing the smell?
With rim brakes, your wheel rim is effectively acting as the "rotor." When you brake for a long time - especially while controlling speed on steep gradients - you convert a lot of kinetic energy into heat at the rim and pad contact surface.
That heat can lead to odour for a few reasons:
  • Pad compound heating up: Polymer-based or composite pad materials can release a noticeable smell when they get hot, much like hot car tyres or hard braking in a vehicle.
  • Resin + surface transfer: On carbon braking tracks, a thin layer of pad material can transfer to the rim during bedding-in. Heat can make this more noticeable at first.
  • "New pad" bedding-in: Fresh pads can smell more during the first few rides as the surface settles, conforms to the rim track, and sheds any tiny manufacturing residues.
In many cases, the smell fades after a couple of rides once everything is bedded in and you've dialled in braking technique for long descents.
Smell vs. problem: how to tell the difference
A smell alone is usually a signal of heat, not automatically a defect. Even so, it's a cue that you're generating significant heat, so adjust technique and give the system a quick check. What matters is what you see and feel at the lever and on the pads.
Usually normal (monitor, but rideable):
  • Warm or slightly burnt-rubber odour after a long descent
  • Braking power feels consistent (no sudden drop)
  • Pads look intact (no cracks, crumbling, or melting)
  • Rim braking surface looks even (no obvious damage)
Stop riding and inspect immediately if you notice:
  • Smoke from the rim or pad area
  • A sudden loss of braking power (fading that doesn't recover quickly)
  • Rapid or uneven pad wear after one descent
  • Glazed pads (shiny, glassy surface that squeals and grips poorly)
  • Rim damage (visible discoloration, bulging, rippling, or unusual texture)
If any of the "stop" signs appear, don't try to "ride it out." Heat-related issues can escalate quickly, especially on very long descents.
How to reduce heat buildup on long descents
The fastest way to make rim brakes run hot is to apply constant light pressure for minutes at a time. A better approach is to brake in short, firm intervals. This reduces average heat and gives the rim time to shed temperature between braking moments.
  1. Use short, firm braking pulses: Brake to scrub speed, release to let things cool, then repeat - rather than dragging the brakes continuously.
  2. Alternate front and rear braking: Sharing the workload helps prevent one rim from taking all the heat.
  3. Plan your speed early: Brake before corners and steep pitches instead of trying to "hold speed" all the way down.
  4. Stay relaxed at the lever: Death-gripping the brakes often turns into brake-dragging, so keep inputs light and intentional.
If you remember one thing: don't drag the brakes. Heat is the enemy of consistent rim-brake performance on long descents -- especially with carbon rims.
Pad inspection: a quick checklist
After a big descent (or if you notice odour), give your pads a quick look. You're checking for heat damage and contamination.
Pad check:
Surface: matte and even (not glossy/glazed)
Edges: not crumbling or cracking
Shape: not melted, smeared, or deformed
Debris: no embedded grit or metal shards
Feel: braking remains predictable and smooth
If everything looks normal and braking feels consistent, the smell was most likely just heat and bedding-in.
Why rider weight, bike load, and terrain matter (a lot)
Two riders can descend the same road with the same pads and have totally different experiences. Heat is heavily influenced by how much energy the braking system has to absorb.
Common factors that increase rim temperature:
  • Heavier riders (more mass = more energy to dissipate)
  • Loaded bikes (commuting bags, bikepacking, touring setups)
  • Very long descents (e.g., Alpine descents)
  • Steeper gradients (more braking demand)
  • Low-speed "control riding" (constant brake input rather than flowing speed)
So if you're running a deeper carbon rim (like a 55 mm road setup) and doing big mountain descents, it's normal to pay extra attention to technique and post-ride checks.
Bedding-in: what to expect from new carbon-specific pads
New pads often improve noticeably after the first handful of braking cycles. Bedding-in helps create a stable, consistent contact layer between pad and braking surface.
A simple bedding routine:
  1. Find a safe flat or gentle downhill road.
  2. Do 10-15 controlled stops from moderate speed.
  3. Let the rims cool briefly between sets.
  4. Avoid one long, heat-soaking descent as your very first ride on brand-new pads.
This doesn't eliminate heat (long descents will always generate plenty), but it can reduce early-life odour and help braking feel smoother and more predictable.
A note on safety: carbon rims and heat
Carbon rim braking systems have come a long way, but heat management is still important on road bikes. Always follow:
  • Your rim manufacturer's guidance for pad compatibility and braking limits
  • DiscoBrakes installation and setup recommendations for these pads
  • Correct toe-in/alignment and clean braking tracks
If you're ever unsure whether what you're experiencing is "normal heat smell" or something more serious, it's worth taking a cautious approach: inspect, cool down, and seek advice before your next big descent.
Where to go from here
A warm or burnt-rubber smell after a long downhill run can be completely normal with rim brakes - especially when pads are new or the descent is steep and sustained. The goal isn't "no heat ever" (impossible), but controlled heat, consistent braking, and regular inspection.
If you want more setup tips and product info for carbon rim braking, here are a few rim-brake reads from the DiscoBrakes blog:
by support     Sun Dec 14, 2025
