First World Cup Win: What It Teaches About Braking Control
2001, a First World Cup Win - and a Braking Time Capsule Worth Rewatching
If you've ever wondered what elite cross-country racing felt like before today's modern race coverage, this short throwback clip delivers it in under a minute.
The video jumps between start-line chaos, a narrow dirt ribbon of singletrack under the trees, and the moment the Jose rolls under a Tissot UCI Mountain Bike World Cup banner with arms raised. Seconds later, the barriers disappear behind a wall of cameras, team staff, and fans - exactly the kind of finish-line intensity that makes World Cup racing what it is.
It's also a reminder of something we care about deeply at DiscoBrakesDiscoBrakes[/url)]: when speeds are high and the margins are tiny, braking isn't a detail - it's a deciding factor.
A 45-second reminder of what racing asks from your brakes
Even in this brief clip, you can see the inputs that define high-level XC:
  • Fast transitions from open, paved finish straights to tight, off-camber dirt
  • Hard accelerations, then quick speed checks into corners
  • Surfaces where traction comes and goes
  • Crowded course edges, where precision matters as much as power
Whether you're racing a local series, riding trails with friends, or chasing KOMs on a loop you know by heart, the fundamentals don't change:
Your brakes need to be predictable. Every time.
2001 vs. now: what's changed (and what hasn't)
A lot has evolved since that early-2000s era - bike geometry, wheel sizes, suspension performance, tire casings, and course design. But one of the biggest performance jumps in mountain biking has been the braking system's steady evolution toward:
More consistency under heat and load
Longer descents, heavier riders, higher speeds, and more aggressive tires all mean more energy to manage. Modern disc systems (and modern rotor and pad options) are designed to shed heat and maintain feel when the pace stays high.
Better modulation
The fastest riders don't just "brake late." They brake well: controlled pressure, minimal skidding, clean releases, and smooth transitions back to power. That kind of modulation is built on good technique - but it also depends on the pad/rotor setup being matched to the ride.
More choice (which is a blessing and a trap)
Today, riders can tune braking performance with:
The upside is performance you can tailor to your terrain. The downside is that a mismatched setup can feel vague, noisy, or inconsistent - especially when conditions change.
Three brake takeaways to do before your next ride
Nostalgia is great. But the best "throwback" moment is when your lever feel is perfect on the first corner.
Here are three practical checks that prevent most brake issues riders fight all season:
  1. Check pad life and pad condition
    It's not just about thickness. Look for glazing (shiny, hardened surface), contamination (oily look/smell; sudden loss of bite), and uneven wear (often a sign the caliper needs alignment). If the pad material is getting thin, replace early - especially before a trip or a race block. Worn pads heat up faster and fade sooner.
  2. Inspect the rotor for straightness and surface health
    A rotor can be "fine" until it isn't - then you're chasing rub, noise, or pulsing. Spin the wheel and listen for periodic contact, look for discoloration (overheating) or deep scoring, and confirm you're above the rotor's minimum thickness. If braking feels inconsistent despite good pads, the rotor surface is often the culprit.
  3. Bed in pads properly - every time
    New pads (and new rotors) need a controlled break-in to deposit an even transfer layer. Skipping this step is one of the fastest routes to weak bite, noise, premature glazing, and "it feels fine... until the first hard stop." If you're installing fresh pads before a big ride, give yourself time for a proper bed-in session - don't make the descent your first test.
Why this matters to us at DiscoBrakes
We love clips like this because they show the sport's roots: raw footage, huge crowds, and a rider experiencing a career milestone in real time.
But they also underline why we focus on performance components riders can trust. When you're moving fast on unpredictable surfaces, confidence comes from consistency - and consistency comes from the details: the right pads, the right rotor, correct setup, and good maintenance.
If your current brakes feel inconsistent from ride to ride, noisy after a pad change, underpowered on long descents, or "grabby" in the wet, there's usually a straightforward fix - and it often starts with dialing in the pad/rotor match for your terrain and riding style.
Credit
This clip was shared with tags referencing @josehermida and @floinemedia. If you're the original creator/rightsholder and would like specific credit language added, we're happy to include it.
by support     Thu Jan 8, 2026
